Saltar al contenido principal
Asus Chromebook C201PA-DS02-LG Motherboard Replacement
Qué necesitas
  1. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: paso 1, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: paso 1, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Keyboard: paso 1, imagen 3 de 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 2, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 3, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 4, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 4, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 4, imagen 3 de 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 5, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 5, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: paso 6, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: paso 6, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Metal Plate: paso 6, imagen 3 de 3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Motherboard: paso 7, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Motherboard Replacement, Motherboard: paso 7, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the 4mm screw. Rotate the screwdriver in a counterclockwise direction to undo the screw.
  8. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 8, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 8, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Use tweezers to gently pull upward on the adhesive black tape.
  9. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 9, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 9, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 9, imagen 3 de 3
    • Use tweezers to pull upward and pop off the wifi antenna cables.
    • Removing the cables may cause popping noises.
  10. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 10, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 10, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 10, imagen 3 de 3
    • Use tweezers to gently pull upward and pop off the LCD cable. It may help to do this on each side of the attachment, rather than in one pull.
    • Removing the cable may cause popping noises.
  11. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 11, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 11, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 11, imagen 3 de 3
  12. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 12, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 12, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 12, imagen 3 de 3
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  13. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 13, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 13, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 13, imagen 3 de 3
    • Use tweezers to gently grasp the wire connector and pull straight back.
  14. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 14, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 14, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • One of the screws may be hidden underneath the black LCD connector.
  15. Asus Chromebook C201PA-DS02-LG Motherboard Replacement: paso 15, imagen 1 de 1
    • Use a plastic opening tool to lift the motherboard off the bottom. You may need to wiggle it around to get it loose.
Conclusión
Brittany M Won
Miembro Desde 04/18/18
577 Reputación
5 Guías creadas
Equipo
Cal Poly, Team S17-G4, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
Miembros de 4
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 355
