Saltar al contenido principal
Asus Chromebook C201PA-DS02-LG Battery Replacement
Qué necesitas
  1. Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: paso 1, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: paso 1, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Keyboard: paso 1, imagen 3 de 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 2, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 2, imagen 2 de 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 3, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 3, imagen 2 de 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 4, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 4, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 4, imagen 3 de 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 5, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 5, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 5, imagen 3 de 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: paso 6, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: paso 6, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Metal Plate: paso 6, imagen 3 de 3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: paso 7, imagen 1 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: paso 7, imagen 2 de 3 Asus Chromebook C201PA-DS02-LG Battery Replacement, Battery: paso 7, imagen 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
    • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  8. Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 8, imagen 1 de 2 Asus Chromebook C201PA-DS02-LG Battery Replacement: paso 8, imagen 2 de 2
    • Use the plastic opening tool to lift up the battery and remove it.
    • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
Conclusión
Ashley Humpal
Miembro Desde 04/18/18
185 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S17-G4, Livingston Spring 2018 Miembro de Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 389
