Saltar al contenido principal
Asus Chromebook C201 Motherboard Replacement
Qué necesitas
  1. Asus Chromebook C201 Motherboard Replacement, Palm Rest Assembly: paso 1, imagen 1 de 1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Motherboard Replacement: paso 3, imagen 1 de 1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Motherboard Replacement: paso 4, imagen 1 de 1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Motherboard Replacement: paso 5, imagen 1 de 2 Asus Chromebook C201 Motherboard Replacement: paso 5, imagen 2 de 2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Motherboard Replacement: paso 6, imagen 1 de 3 Asus Chromebook C201 Motherboard Replacement: paso 6, imagen 2 de 3 Asus Chromebook C201 Motherboard Replacement: paso 6, imagen 3 de 3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Motherboard Replacement: paso 7, imagen 1 de 2 Asus Chromebook C201 Motherboard Replacement: paso 7, imagen 2 de 2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Motherboard Replacement, Motherboard: paso 9, imagen 1 de 1
    Herramienta utilizada en este paso:
    • Use tweezers to disconnect the LCD cable from the motherboard.
  10. Asus Chromebook C201 Motherboard Replacement: paso 10, imagen 1 de 1
    • Use the tweezers to disconnect both wifi antenna cables from the motherboard.
  11. Asus Chromebook C201 Motherboard Replacement: paso 11, imagen 1 de 2 Asus Chromebook C201 Motherboard Replacement: paso 11, imagen 2 de 2
    • Use a J0 Phillips screwdriver to remove the 6, 4mm small head silver screws.
    • Use the same J0 Phillips screwdriver to remove the 4mm large head silver screw from the head shield.
    • Remove the heat shield.
  12. Asus Chromebook C201 Motherboard Replacement: paso 12, imagen 1 de 1
    • Use the tweezers to disconnect the battery cable from the motherboard.
  13. Asus Chromebook C201 Motherboard Replacement: paso 13, imagen 1 de 1
    • Use the tweezers to disconnect the daughterboard plug from the motherboard.
  14. Asus Chromebook C201 Motherboard Replacement: paso 14, imagen 1 de 2 Asus Chromebook C201 Motherboard Replacement: paso 14, imagen 2 de 2
    • Remove the sound cable from motherboard.
  15. Asus Chromebook C201 Motherboard Replacement: paso 15, imagen 1 de 1
    • Use a J0 Phillips screwdriver to remove the single, silver, 4mm screw on the motherboard.
  16. Asus Chromebook C201 Motherboard Replacement: paso 16, imagen 1 de 1
    • Remove the motherboard.
Conclusión
7 personas más completaron esta guía.
Bryan Franz
Miembro Desde 02/09/16
476 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 2-51, Cagle Spring 2016 Miembro de USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
Miembros de 4
10 Guías creadas
1Guía Comentario
Hello
Where can we find this motherboard for the asus C201PA chromebook ?
Jean-Vincent - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 12
Todo El Tiempo: 3,466
