Saltar al contenido principal
Asus Chromebook C201 Battery Replacement
Qué necesitas
  1. Asus Chromebook C201 Battery Replacement, Palm Rest Assembly: paso 1, imagen 1 de 1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Battery Replacement: paso 2, imagen 1 de 1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Battery Replacement: paso 3, imagen 1 de 1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Battery Replacement: paso 4, imagen 1 de 1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Battery Replacement: paso 5, imagen 1 de 2 Asus Chromebook C201 Battery Replacement: paso 5, imagen 2 de 2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Battery Replacement: paso 6, imagen 1 de 3 Asus Chromebook C201 Battery Replacement: paso 6, imagen 2 de 3 Asus Chromebook C201 Battery Replacement: paso 6, imagen 3 de 3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Battery Replacement: paso 7, imagen 1 de 2 Asus Chromebook C201 Battery Replacement: paso 7, imagen 2 de 2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Battery Replacement: paso 8, imagen 1 de 1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Battery Replacement, Battery: paso 9, imagen 1 de 2 Asus Chromebook C201 Battery Replacement, Battery: paso 9, imagen 2 de 2
    • Use a J0 screwdriver to remove the seven 4mm silver heat shield screws and remove the heat shield.
  10. Asus Chromebook C201 Battery Replacement: paso 10, imagen 1 de 1
    • Pull the battery cable from the motherboard.
  11. Asus Chromebook C201 Battery Replacement: paso 11, imagen 1 de 1
    • Use a J0 Phillips screwdriver to remove the 5, 4mm silver battery screws from the battery.
  12. Asus Chromebook C201 Battery Replacement: paso 12, imagen 1 de 1
    • Grab the the battery and remove it from the Chromebook.
Conclusión
9 personas más completaron esta guía.
Robert Lawson
Miembro Desde 02/09/16
841 Reputación
3 Guías creadas
Equipo
USF Tampa, Team 2-51, Cagle Spring 2016 Miembro de USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Miembros
10 Guías creadas
2 comentarios
This was a great guide to replacing the battery in the ASUS chromebook C201 PA. I left the instructions displayed on my regular lap top as I went thru the steps. There was a trick when it came to disconnecting the keyboard plugs. The tabs that were supposed to be bent up to enable the unplugging weren’t there and rather than fiddle around trying to unplug them in some other way I just left them connected and manipulated the key board very carefully when needed. A second set of steady hands can help.
Doug Hooper - Contestar
I first looked for a YouTube video for info, silly me. They showed removing the lid and disconnecting all the accompanying cables! It didn’t look necessary to me, and as this guide shows, it isn’t.
I do find it curious as it looks to me like the lid is lying flat, I wonder if the author loosened or removed the lid hinge screws to allow that. That might simplify things.
The battery failed in mine, I’m debating whether or not it’s worthwhile to replace in a five year old device that cost $200ish to originally purchase.
Wayne West - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 13
Todo El Tiempo: 4,418
