Saltar al contenido principal
Asus Chromebook C101P Touchpad Replacement
Qué necesitas
  1. Asus Chromebook C101P Touchpad Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Touchpad Replacement: paso 2, imagen 1 de 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Touchpad Replacement: paso 3, imagen 1 de 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Touchpad Replacement: paso 4, imagen 1 de 2 Asus Chromebook C101P Touchpad Replacement: paso 4, imagen 2 de 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Touchpad Replacement: paso 5, imagen 1 de 3 Asus Chromebook C101P Touchpad Replacement: paso 5, imagen 2 de 3 Asus Chromebook C101P Touchpad Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Touchpad Replacement, Touchpad: paso 6, imagen 1 de 3 Asus Chromebook C101P Touchpad Replacement, Touchpad: paso 6, imagen 2 de 3 Asus Chromebook C101P Touchpad Replacement, Touchpad: paso 6, imagen 3 de 3
    • Remove the three Phillips #0 screws holding the trackpad in place.
  7. Asus Chromebook C101P Touchpad Replacement: paso 7, imagen 1 de 3 Asus Chromebook C101P Touchpad Replacement: paso 7, imagen 2 de 3 Asus Chromebook C101P Touchpad Replacement: paso 7, imagen 3 de 3
    • Using tweezers, pull the cable free from the touchpad.
    • Using tweezers, pry off the tape holding the touchpad down.
Conclusión
Bryan Acosta
Miembro Desde 10/25/19
377 Reputación
3 Guías creadas
Equipo
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Miembro de UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
Miembros de 2
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 431
