Saltar al contenido principal
Asus Chromebook C101P Speakers Replacement
Qué necesitas
  1. Asus Chromebook C101P Speakers Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Speakers Replacement: paso 2, imagen 1 de 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Speakers Replacement: paso 3, imagen 1 de 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Speakers Replacement: paso 4, imagen 1 de 2 Asus Chromebook C101P Speakers Replacement: paso 4, imagen 2 de 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Speakers Replacement: paso 5, imagen 1 de 3 Asus Chromebook C101P Speakers Replacement: paso 5, imagen 2 de 3 Asus Chromebook C101P Speakers Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Speakers Replacement, Speakers: paso 6, imagen 1 de 1
    • Remove the four Phillips #0 screws from the speakers.
  7. Asus Chromebook C101P Speakers Replacement: paso 7, imagen 1 de 1
    Comprar
    • Remove the yellow speaker tape using tweezers.
  8. Asus Chromebook C101P Speakers Replacement: paso 8, imagen 1 de 2 Asus Chromebook C101P Speakers Replacement: paso 8, imagen 2 de 2
    • Detach the right speaker using tweezers.
    • The right speaker has its own set of cables connecting to the motherboard. Simply tug on the cables.
Conclusión
Bryan Acosta
Miembro Desde 10/25/19
329 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 6
Todo El Tiempo: 376
