Saltar al contenido principal
Asus Chromebook C101P Screen Replacement
Qué necesitas
  1. Asus Chromebook C101P Screen Replacement, Keyboard: paso 1, imagen 1 de 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Screen Replacement: paso 2, imagen 1 de 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Screen Replacement: paso 3, imagen 1 de 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Screen Replacement: paso 4, imagen 1 de 2 Asus Chromebook C101P Screen Replacement: paso 4, imagen 2 de 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Screen Replacement: paso 5, imagen 1 de 3 Asus Chromebook C101P Screen Replacement: paso 5, imagen 2 de 3 Asus Chromebook C101P Screen Replacement: paso 5, imagen 3 de 3
    Herramienta utilizada en este paso:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Screen Replacement, Screen: paso 6, imagen 1 de 2 Asus Chromebook C101P Screen Replacement, Screen: paso 6, imagen 2 de 2
    • Detach the the screen cables from the motherboard using a pair of tweezers.
    • Peel off the tape or seal to easily remove the screen cables.
  7. Asus Chromebook C101P Screen Replacement: paso 7, imagen 1 de 2 Asus Chromebook C101P Screen Replacement: paso 7, imagen 2 de 2
    • Remove the Phillips 00 screws from the hinges.
  8. Asus Chromebook C101P Screen Replacement: paso 8, imagen 1 de 1
    • Angle the hinge as shown and use a T5 Torx screwdriver to remove the hinge screws.
  9. Asus Chromebook C101P Screen Replacement: paso 9, imagen 1 de 2 Asus Chromebook C101P Screen Replacement: paso 9, imagen 2 de 2
    • Pry open the hinge by using the iFixit opening tool.
  10. Asus Chromebook C101P Screen Replacement: paso 10, imagen 1 de 1
    • Use the iFixit opening tool to pop out the black rubber grips near the bottom of the screen.
    • Use a Phillips 00 screwdriver to remove the screws beneath the rubber grips.
  11. Asus Chromebook C101P Screen Replacement: paso 11, imagen 1 de 3 Asus Chromebook C101P Screen Replacement: paso 11, imagen 2 de 3 Asus Chromebook C101P Screen Replacement: paso 11, imagen 3 de 3
    • Use the iFixit opening tool to pry around the screen.
    • Use the space between the screen and the hinge to prop it up.
    • Once open, slide the wires that are in the hinge out. The screen should now be fully detached from the case.
Conclusión
2 personas más completaron esta guía.
Dan Sysopha
Miembro Desde 10/25/19
369 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Miembro de UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
Miembros de 2
5 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 40
Todo El Tiempo: 2,381
