Saltar al contenido principal
Envío gratis en pedidos nacionales de $75+
Asus Chromebook C101P Heat Sink Replacement
Vistas: 1.6 k
Ver estadísticas:
Últimas 24 horas:
3
Últimos 7 días:
13
Últimos 30 días:
62
Todo El Tiempo:
1,611
Comentarios: 2
2 comentarios sobre los pasos.
Completado: 0
Nadie ha marcado esta guía como "completada". ¿Quieres marcarla tú?
Favoritos: 0
Nadie ha marcado como "Favorita" ni se ha suscrito a esta guía. ¿Quieres hacerlo tú?
Tiempo Requerido: 15 - 20 minutos
Dificultad: Moderado
Introducción
Ir al paso 1 ↓
The Asus Chromebook C101P only has one item keeping it from overheating. The heat sink is an L-shaped piece of copper that is attached to the CPU on the motherboard to dissipate heat. It is attached using thermal paste so be sure to have some on hand. Ensure that the Chromebook is fully powered off and not plugged in before removing the heat sink. Also, be sure to wait a few minutes after powering off, as the heat sink may be hot.
Qué necesitas
Herramientas
    1. Asus Chromebook C101P Heat Sink Replacement, Keyboard: paso 1, imagen 1 de 1
      • Flip the Chromebook so that the bottom is facing up.
      • Remove the nine T5 Torx screws.
      Pregunta a FixBot
      Agregar Comentario
    2. Asus Chromebook C101P Heat Sink Replacement: paso 2, imagen 1 de 1
      • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
      Pregunta a FixBot
      Agregar Comentario
    3. Asus Chromebook C101P Heat Sink Replacement: paso 3, imagen 1 de 1
      • Remove the four black screws where the rubber grips were.
      Pregunta a FixBot
      Agregar Comentario
    4. Asus Chromebook C101P Heat Sink Replacement: paso 4, imagen 1 de 2 Asus Chromebook C101P Heat Sink Replacement: paso 4, imagen 2 de 2
      • Reorient the Chromebook so the right side is facing upwards.
      • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
      Pregunta a FixBot
      Agregar Comentario
    5. Asus Chromebook C101P Heat Sink Replacement: paso 5, imagen 1 de 3 Asus Chromebook C101P Heat Sink Replacement: paso 5, imagen 2 de 3 Asus Chromebook C101P Heat Sink Replacement: paso 5, imagen 3 de 3
      Herramienta utilizada en este paso:
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
      • Separate the keyboard from the rest of the laptop.
      Pregunta a FixBot
      Agregar Comentario
    1. Asus Chromebook C101P Heat Sink Replacement, Heat Sink: paso 6, imagen 1 de 2 Asus Chromebook C101P Heat Sink Replacement, Heat Sink: paso 6, imagen 2 de 2
      • Detach the the screen cables from the motherboard using a pair of tweezers.
      • Peel off the tape or seal to easily remove the screen cables.
      Pregunta a FixBot
      Agregar Comentario
    2. Asus Chromebook C101P Heat Sink Replacement: paso 7, imagen 1 de 1
      • Flip up the black lever on the base of the small white ribbon cable. Remove the cable and set it aside.
      Pregunta a FixBot
      Agregar Comentario
    3. Asus Chromebook C101P Heat Sink Replacement: paso 8, imagen 1 de 1
      • Remove the nine Phillips #0 screws.
      • The 3 circles on the hand indicate that there are 3 more screws not visible in the photo.
      • Remove the battery cable if possible. Otherwise, gently flip the motherboard upside down to reveal the heat sink.
      • The motherboard may be hot. Be sure that you have left the Chromebook turned off for a few minutes.
      Pregunta a FixBot
      Agregar Comentario
    4. Asus Chromebook C101P Heat Sink Replacement: paso 9, imagen 1 de 2 Asus Chromebook C101P Heat Sink Replacement: paso 9, imagen 2 de 2
      • Remove the four Phillips #0 screws from the heat sink.
      • Detach the heat sink from the motherboard.
      • Detaching may provide a bit of resistance because of thermal paste.
      • When you are ready to apply the new heat sink, be sure to apply a small dab of thermal paste onto the CPU.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
Autor
con
Dan Sysopha
Miembro Desde 10/25/19
369 Reputación
2 Guías creadas
Equipo
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Miembro de UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
Miembros de 2
60 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 13
Ultimos 30 días: 62
Todo El Tiempo: 1,611
