Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
If your computer is having trouble reading or writing on optical discs such as CDs and DVDs, and you have also ruled out software difficulties, this guide will show how to replace your optical drive.
Partes
No se especificaron partes.
  1. Make sure the laptop is off. Flip the laptop upside down so that the battery is facing you.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Move the two sliders towards the outer edge of the laptop. Pull the battery out with your left hand while holding the right slider.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. El kit de herramientas esencial
    Las herramientas más útiles en nuestro kit más compacto.
    Compra ahora
    Compra ahora
  4. Remove the 5mm screw using a Phillips #1 screwdriver. Use the iFixit opening tools to remove the RAM panel. Use the iFixit opening tools to remove the RAM panel.
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  5. Remove the 7mm screw using a Phillips #1 screwdriver. Pull the optical drive out from the side of the laptop. Pull the optical drive out from the side of the laptop.
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
Conclusión
Chase Poirier
Miembro Desde 23/10/18
505 Reputación
5 Guías creadas
Equipo
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 151
