Saltar al contenido principal
Asus A53U-ES21 Motherboard Replacement
Qué necesitas
  1. Asus A53U-ES21 Motherboard Replacement, Battery: paso 1, imagen 1 de 2 Asus A53U-ES21 Motherboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Motherboard Replacement: paso 2, imagen 1 de 2 Asus A53U-ES21 Motherboard Replacement: paso 2, imagen 2 de 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Motherboard Replacement, Optical Drive: paso 3, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement, Optical Drive: paso 3, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement, Optical Drive: paso 3, imagen 3 de 3
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the RAM panel.
  4. Asus A53U-ES21 Motherboard Replacement: paso 4, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement: paso 4, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement: paso 4, imagen 3 de 3
    • Remove the 7mm screw using a Phillips #1 screwdriver.
    • Pull the optical drive out from the side of the laptop.
  5. Asus A53U-ES21 Motherboard Replacement, Keyboard: paso 5, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement, Keyboard: paso 5, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement, Keyboard: paso 5, imagen 3 de 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  6. Asus A53U-ES21 Motherboard Replacement: paso 6, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement: paso 6, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement: paso 6, imagen 3 de 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  7. Asus A53U-ES21 Motherboard Replacement: paso 7, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement: paso 7, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement: paso 7, imagen 3 de 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
  8. Asus A53U-ES21 Motherboard Replacement, Motherboard: paso 8, imagen 1 de 1
    • Close the laptop and place it upside down.
    • Remove the twelve 7mm screws using a Phillips #1 screwdriver.
  9. Asus A53U-ES21 Motherboard Replacement: paso 9, imagen 1 de 1
    • Remove the two 2mm screws using a Phillips #1 screwdriver.
  10. Asus A53U-ES21 Motherboard Replacement: paso 10, imagen 1 de 2 Asus A53U-ES21 Motherboard Replacement: paso 10, imagen 2 de 2
    • Pull the connectors away from the wireless card using the plastic opening tools.
    • Pull the white connector from its socket in the RAM panel.
  11. Asus A53U-ES21 Motherboard Replacement: paso 11, imagen 1 de 1
    • Flip the laptop over again, open it, and unscrew the three 7mm screws using a Phillips #1 screwdriver.
  12. Asus A53U-ES21 Motherboard Replacement: paso 12, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement: paso 12, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement: paso 12, imagen 3 de 3
    • Gently pull the tan flap off of the cable using the plastic opening tool.
    • Push the tan piece towards the cable and release it using the plastic opening tool.
    • Pull the black flap off of its connector.
  13. Asus A53U-ES21 Motherboard Replacement: paso 13, imagen 1 de 2 Asus A53U-ES21 Motherboard Replacement: paso 13, imagen 2 de 2
    • Separate the front plate of the laptop from the back using the plastic opening tool.
  14. Asus A53U-ES21 Motherboard Replacement: paso 14, imagen 1 de 3 Asus A53U-ES21 Motherboard Replacement: paso 14, imagen 2 de 3 Asus A53U-ES21 Motherboard Replacement: paso 14, imagen 3 de 3
    • Remove the single 7mm screw from the motherboard using a Phillips #1 screwdriver.
    • Pull to two shown cables from their sockets using the plastic opening tools.
    • Gently remove the motherboard from the laptop.
Conclusión
2 personas más completaron esta guía.
Chase Poirier
Miembro Desde 10/23/18
544 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 847
