Saltar al contenido principal
Asus A53U-ES21 Keyboard Replacement
Qué necesitas
  1. Asus A53U-ES21 Keyboard Replacement, Battery: paso 1, imagen 1 de 2 Asus A53U-ES21 Keyboard Replacement, Battery: paso 1, imagen 2 de 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Keyboard Replacement: paso 2, imagen 1 de 2 Asus A53U-ES21 Keyboard Replacement: paso 2, imagen 2 de 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: paso 3, imagen 1 de 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: paso 3, imagen 2 de 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: paso 3, imagen 3 de 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  4. Asus A53U-ES21 Keyboard Replacement: paso 4, imagen 1 de 3 Asus A53U-ES21 Keyboard Replacement: paso 4, imagen 2 de 3 Asus A53U-ES21 Keyboard Replacement: paso 4, imagen 3 de 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  5. Asus A53U-ES21 Keyboard Replacement: paso 5, imagen 1 de 3 Asus A53U-ES21 Keyboard Replacement: paso 5, imagen 2 de 3 Asus A53U-ES21 Keyboard Replacement: paso 5, imagen 3 de 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
Conclusión
Una persona más ha completado esta guía.
Mabel Trager
Miembro Desde 10/23/18
147 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 21
Todo El Tiempo: 517
