Introducción
Is your computer heating up quickly or making loud noises? Consider using this guide to replace the fan in your device.
Qué necesitas
Remove the 5mm screw using a Phillips #1 screwdriver.
Use the iFixit opening tools to remove the RAM panel.
Remove the RAM cover from the bottom of the keyboard.
Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
Work the pry tool along the edge to finish removal.
Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
Orient the computer so the keyboard is facing toward you with the screen at the top.
Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
Use the pry tool to depress the buttons. The keyboard should pop out.
Close the laptop and place it upside down.
Remove the twelve 7mm screws using a Phillips #1 screwdriver.
To remove the heat sink, unscrew the four 7mm screws using a Phillips #1 screwdriver.
Remove the heatsink from the device.
To remove the fan, unscrew the three 5mm screws using a Phillips #1 screwdriver and pull the shown cable from its socket.
