Saltar al contenido principal
Asus A52F Hard Drive Replacement
Qué necesitas
  1. Asus A52F Hard Drive Replacement, Battery: paso 1, imagen 1 de 2 Asus A52F Hard Drive Replacement, Battery: paso 1, imagen 2 de 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: paso 2, imagen 1 de 2 Asus A52F Hard Drive Replacement: paso 2, imagen 2 de 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: paso 3, imagen 1 de 3 Asus A52F Hard Drive Replacement, Lower Case: paso 3, imagen 2 de 3 Asus A52F Hard Drive Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: paso 4, imagen 1 de 2 Asus A52F Hard Drive Replacement: paso 4, imagen 2 de 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: paso 5, imagen 1 de 3 Asus A52F Hard Drive Replacement, Hard Drive: paso 5, imagen 2 de 3 Asus A52F Hard Drive Replacement, Hard Drive: paso 5, imagen 3 de 3
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: paso 6, imagen 1 de 2 Asus A52F Hard Drive Replacement: paso 6, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: paso 7, imagen 1 de 2 Asus A52F Hard Drive Replacement: paso 7, imagen 2 de 2
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Conclusión
Una persona más ha completado esta guía.
Roman Justice
Miembro Desde 03/08/17
225 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 17
Todo El Tiempo: 1,527
