Saltar al contenido principal
Asus A52F Cooling System Replacement
Qué necesitas
  1. Asus A52F Cooling System Replacement, Battery: paso 1, imagen 1 de 2 Asus A52F Cooling System Replacement, Battery: paso 1, imagen 2 de 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Cooling System Replacement: paso 2, imagen 1 de 2 Asus A52F Cooling System Replacement: paso 2, imagen 2 de 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Cooling System Replacement, Lower Case: paso 3, imagen 1 de 3 Asus A52F Cooling System Replacement, Lower Case: paso 3, imagen 2 de 3 Asus A52F Cooling System Replacement, Lower Case: paso 3, imagen 3 de 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Cooling System Replacement: paso 4, imagen 1 de 2 Asus A52F Cooling System Replacement: paso 4, imagen 2 de 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Cooling System Replacement, Cooling System: paso 5, imagen 1 de 2 Asus A52F Cooling System Replacement, Cooling System: paso 5, imagen 2 de 2
    • Removal of cooling system will void your warranty. Proceed with caution.
  6. Asus A52F Cooling System Replacement: paso 6, imagen 1 de 2 Asus A52F Cooling System Replacement: paso 6, imagen 2 de 2
    • Using a Phillips #0 screwdriver, remove all six screws from the cooling system.
    • Unplug the fan power connector.
  7. Asus A52F Cooling System Replacement: paso 7, imagen 1 de 2 Asus A52F Cooling System Replacement: paso 7, imagen 2 de 2
    • Carefully grab the copper pipe and start to lift upward.
    • Lift to the angle shown and then start to slide it out.
  8. Asus A52F Cooling System Replacement: paso 8, imagen 1 de 1
    • Clean the designated area with isopropyl alcohol on a microfiber cloth
    • Replace with new thermal paste if needed
Conclusión
2 personas más completaron esta guía.
Bradley Varnum
Miembro Desde 03/09/17
294 Reputación
2 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 28
Todo El Tiempo: 894
