Saltar al contenido principal
Asus 1015E-DS03 Screen Replacement
Qué necesitas
  1. Asus 1015E-DS03 Screen Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Screen Replacement: paso 2, imagen 1 de 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Screen Replacement: paso 3, imagen 1 de 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Screen Replacement: paso 4, imagen 1 de 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: paso 5, imagen 1 de 1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Screen Replacement: paso 6, imagen 1 de 2 Asus 1015E-DS03 Screen Replacement: paso 6, imagen 2 de 2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Screen Replacement: paso 7, imagen 1 de 1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
  8. Asus 1015E-DS03 Screen Replacement, Screen: paso 8, imagen 1 de 1
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
  9. Asus 1015E-DS03 Screen Replacement: paso 9, imagen 1 de 2 Asus 1015E-DS03 Screen Replacement: paso 9, imagen 2 de 2
    • Lift the screen away from the computer.
    • Be careful removing the screen, as the left side is still connected to the computer.
  10. Asus 1015E-DS03 Screen Replacement: paso 10, imagen 1 de 2 Asus 1015E-DS03 Screen Replacement: paso 10, imagen 2 de 2
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
  11. Asus 1015E-DS03 Screen Replacement: paso 11, imagen 1 de 1
    • Separate the screen from the computer by gently pulling it out.
  12. Asus 1015E-DS03 Screen Replacement: paso 12, imagen 1 de 1
    • Upon removal, the computer should look like this picture.
Conclusión
2 personas más completaron esta guía.
Becca Day
Miembro Desde 03/23/16
297 Reputación
2 Guías creadas
Equipo
Clemson, Team 7-4, Benson Spring 2016 Miembro de Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 8
Todo El Tiempo: 594
