Saltar al contenido principal
Asus 1015E-DS03 Motherboard Replacement
Qué necesitas
  1. Asus 1015E-DS03 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Motherboard Replacement: paso 2, imagen 1 de 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Motherboard Replacement: paso 3, imagen 1 de 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Motherboard Replacement: paso 4, imagen 1 de 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Motherboard Replacement, Keyboard: paso 5, imagen 1 de 1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Motherboard Replacement: paso 6, imagen 1 de 2 Asus 1015E-DS03 Motherboard Replacement: paso 6, imagen 2 de 2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Motherboard Replacement: paso 7, imagen 1 de 1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Motherboard Replacement: paso 8, imagen 1 de 1
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Motherboard Replacement: paso 9, imagen 1 de 2 Asus 1015E-DS03 Motherboard Replacement: paso 9, imagen 2 de 2
    • Gently pull the strip out of the square slot.
  10. Asus 1015E-DS03 Motherboard Replacement, Motherboard: paso 10, imagen 1 de 1
    • Remove the 3mm screws (8) from the motherboard using a #0 Phillips head screwdriver.
    • Carefully and slowly lift the motherboard out of the base of the laptop.
    • In the picture shown, the hard drive has already been removed, although, it is not necessary to remove the hard drive in order to remove the motherboard. Simply disconnect the two ZIF connectors from the hard drive that are labeled "IO" as shown in the picture and leave the hard drive in place.
  11. Asus 1015E-DS03 Motherboard Replacement: paso 11, imagen 1 de 3 Asus 1015E-DS03 Motherboard Replacement: paso 11, imagen 2 de 3 Asus 1015E-DS03 Motherboard Replacement: paso 11, imagen 3 de 3
    • Detach the 3 components (2 wires and 1 chip) prior to completely removing the motherboard.
    • Gently pull on the wire until it comes loose.
    • The wire will offer resistance, but firmly, yet gently, pulling on the wire will release it from its dock.
    • Gently pull the chip out of its dock.
  12. Asus 1015E-DS03 Motherboard Replacement: paso 12, imagen 1 de 2 Asus 1015E-DS03 Motherboard Replacement: paso 12, imagen 2 de 2
    • Gently pull out the final cord.
    • When the wires and chip have been successfully detached from the motherboard, your laptop (and the removed pieces) should resemble the picture.
Conclusión
2 personas más completaron esta guía.
Joe Capriola
Miembro Desde 03/21/16
428 Reputación
3 Guías creadas
Equipo
Clemson, Team 7-4, Benson Spring 2016 Miembro de Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 13
Todo El Tiempo: 1,799
