Introducción
Replacing a hard drive may be necessary if you are experiencing frequent crashes, data loss or file corruption. You also can upgrade the hard drive to store more data. Either way, just follow this simple guide!
Qué necesitas
Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
Once the keyboard is removed, the base plate will be exposed
Remove the 3mm screws (11) using a #0 Phillips head screwdriver
3 personas más completaron esta guía.
