Saltar al contenido principal
Astro Mixamp USB Port Replacement
Qué necesitas
  1. Astro Mixamp USB Port Replacement, Panel Dial: paso 1, imagen 1 de 2 Astro Mixamp USB Port Replacement, Panel Dial: paso 1, imagen 2 de 2
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp USB Port Replacement: paso 2, imagen 1 de 2 Astro Mixamp USB Port Replacement: paso 2, imagen 2 de 2
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp USB Port Replacement, Outer Casing: paso 3, imagen 1 de 2 Astro Mixamp USB Port Replacement, Outer Casing: paso 3, imagen 2 de 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp USB Port Replacement: paso 4, imagen 1 de 1
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp USB Port Replacement: paso 5, imagen 1 de 1
    • Gently lift the rear casing from the device.
  6. Astro Mixamp USB Port Replacement, Motherboard: paso 6, imagen 1 de 3 Astro Mixamp USB Port Replacement, Motherboard: paso 6, imagen 2 de 3 Astro Mixamp USB Port Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp USB Port Replacement: paso 7, imagen 1 de 1
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp USB Port Replacement, USB Port: paso 8, imagen 1 de 3 Astro Mixamp USB Port Replacement, USB Port: paso 8, imagen 2 de 3 Astro Mixamp USB Port Replacement, USB Port: paso 8, imagen 3 de 3
    • Press the tip of a hot soldering iron to the USB connection to melt the solder.
    • Use a nylon spudger to lift the USB from the solder.
    • Repeat for each of the four USB connections.
    • For more help on soldering, refer to this guide: Cómo soldar y desoldar conexiones
Conclusión
2 personas más completaron esta guía.
Hope Burns
Miembro Desde 10/29/16
741 Reputación
5 Guías creadas
Equipo
IUPUI, Team 3-3, Wilson Fall 2016 Miembro de IUPUI, Team 3-3, Wilson Fall 2016
IUPUI-WILSON-F16S3G3
3 Miembros
5 Guías creadas
4 comentarios
What port is used as a replacement?
jonescoleman1738 - Contestar
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
MoreZemtor - Contestar
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 38
Todo El Tiempo: 7,581
