Saltar al contenido principal
Astro Mixamp Control Button Replacement
Qué necesitas
  1. Astro Mixamp Control Button Replacement, Panel Dial: paso 1, imagen 1 de 2 Astro Mixamp Control Button Replacement, Panel Dial: paso 1, imagen 2 de 2
    • Grip the dial tightly and pull straight off the device.
    • Repeat for the second dial
  2. Astro Mixamp Control Button Replacement: paso 2, imagen 1 de 2 Astro Mixamp Control Button Replacement: paso 2, imagen 2 de 2
    • Using tweezers, remove the spacer nuts and washers from each dial post.
  3. Astro Mixamp Control Button Replacement, Outer Casing: paso 3, imagen 1 de 2 Astro Mixamp Control Button Replacement, Outer Casing: paso 3, imagen 2 de 2
    • Before opening your device, ensure the device is not on or connected to the charging cable.
    • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
    • Pull the rubber foot free of the plastic casing.
  4. Astro Mixamp Control Button Replacement: paso 4, imagen 1 de 1
    • Use a screwdriver to remove the screw from the rear casing.
  5. Astro Mixamp Control Button Replacement: paso 5, imagen 1 de 1
    • Gently lift the rear casing from the device.
  6. Astro Mixamp Control Button Replacement, Motherboard: paso 6, imagen 1 de 3 Astro Mixamp Control Button Replacement, Motherboard: paso 6, imagen 2 de 3 Astro Mixamp Control Button Replacement, Motherboard: paso 6, imagen 3 de 3
    • Remove the four screws that hold the motherboard in place.
    • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
  7. Astro Mixamp Control Button Replacement: paso 7, imagen 1 de 1
    • Gently pull the motherboard from the front cover.
  8. Astro Mixamp Control Button Replacement, Control Button: paso 8, imagen 1 de 2 Astro Mixamp Control Button Replacement, Control Button: paso 8, imagen 2 de 2
    • Gently insert a metal spudger under a control button housing.
    • Do not pry the button housing from the front panel, this can cause damage to the button.
    • Rotate the control button around the marked pin.
Conclusión
2 personas más completaron esta guía.
Hope Burns
Miembro Desde 10/29/16
741 Reputación
5 Guías creadas
Equipo
IUPUI, Team 3-3, Wilson Fall 2016 Miembro de IUPUI, Team 3-3, Wilson Fall 2016
IUPUI-WILSON-F16S3G3
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 18
Todo El Tiempo: 1,505
