Saltar al contenido principal
Astro C40 TR Joystick Replacement
Qué necesitas
  1. Astro C40 TR Joystick Replacement, Joystick: paso 1, imagen 1 de 1
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
  2. Astro C40 TR Joystick Replacement: paso 2, imagen 1 de 3 Astro C40 TR Joystick Replacement: paso 2, imagen 2 de 3 Astro C40 TR Joystick Replacement: paso 2, imagen 3 de 3
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
  3. Astro C40 TR Joystick Replacement: paso 3, imagen 1 de 3 Astro C40 TR Joystick Replacement: paso 3, imagen 2 de 3 Astro C40 TR Joystick Replacement: paso 3, imagen 3 de 3
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
  4. Astro C40 TR Joystick Replacement: paso 4, imagen 1 de 3 Astro C40 TR Joystick Replacement: paso 4, imagen 2 de 3 Astro C40 TR Joystick Replacement: paso 4, imagen 3 de 3
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
  5. Astro C40 TR Joystick Replacement: paso 5, imagen 1 de 3 Astro C40 TR Joystick Replacement: paso 5, imagen 2 de 3 Astro C40 TR Joystick Replacement: paso 5, imagen 3 de 3
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
  6. Astro C40 TR Joystick Replacement: paso 6, imagen 1 de 2 Astro C40 TR Joystick Replacement: paso 6, imagen 2 de 2
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
  7. Astro C40 TR Joystick Replacement: paso 7, imagen 1 de 1
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
Conclusión
Pan
Miembro Desde 09/13/21
145 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 20
Ultimos 30 días: 87
Todo El Tiempo: 3,228
