Saltar al contenido principal
Astak Mole Motor Replacement
Qué necesitas
  1. Astak Mole  Motor Replacement, Lower Case: paso 1, imagen 1 de 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole  Motor Replacement: paso 2, imagen 1 de 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole  Motor Replacement: paso 3, imagen 1 de 1
    • Remove the SD card.
  4. Astak Mole  Motor Replacement: paso 4, imagen 1 de 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole  Motor Replacement: paso 5, imagen 1 de 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole  Motor Replacement, Electric Motor Assembly: paso 6, imagen 1 de 1
    • Unscrew both screws using the Phillips head (PH1) screw bit and set aside for reassembly
    • Screw Measurements: Length: 7.1mm
    • The motor should be free of its housing and only be attached to the motherboard by its wires.
  7. Astak Mole  Motor Replacement: paso 7, imagen 1 de 1
    • Sever motor connection to motherboard and remove wire carefully.
    • Optional: Use electrical adhesive to prevent dislodging of new wired connection.
Conclusión
Andrew Birch
Miembro Desde 09/15/16
204 Reputación
2 Guías creadas
Equipo
USF Tampa, Team 2-2, Blackwell Fall 2016 Miembro de USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Miembros
12 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 400
