Saltar al contenido principal
Aroma ARC-914SBD Power Cord Replacement
Qué necesitas
  1. Aroma ARC-914SBD Power Cord Replacement, Lid: paso 1, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement, Lid: paso 1, imagen 2 de 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Power Cord Replacement: paso 2, imagen 1 de 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Power Cord Replacement: paso 3, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement: paso 3, imagen 2 de 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Power Cord Replacement: paso 4, imagen 1 de 3 Aroma ARC-914SBD Power Cord Replacement: paso 4, imagen 2 de 3 Aroma ARC-914SBD Power Cord Replacement: paso 4, imagen 3 de 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. Aroma ARC-914SBD Power Cord Replacement, Heating Element/ Thermostat: paso 5, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement, Heating Element/ Thermostat: paso 5, imagen 2 de 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry this piece from the bottom to get the tab from behind the stainless steel to in front of the steel as shown.
  6. Aroma ARC-914SBD Power Cord Replacement: paso 6, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement: paso 6, imagen 2 de 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. Aroma ARC-914SBD Power Cord Replacement: paso 7, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement: paso 7, imagen 2 de 2
    • Using a Phillips head screwdriver, size PH2, remove the screws from the control module to expose wired connections.
  8. Aroma ARC-914SBD Power Cord Replacement: paso 8, imagen 1 de 1
    • Unplug thermostat from control module
  9. Aroma ARC-914SBD Power Cord Replacement: paso 9, imagen 1 de 1
    • Remove red and blue wires from heating element to fully detach from control module. This is done by removing the screws on the heating element terminals using a Phillips head screwdriver, size PH2.
  10. Aroma ARC-914SBD Power Cord Replacement: paso 10, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement: paso 10, imagen 2 de 2
    • Again, using a Phillips head screwdriver, size PH2, remove the three screws holding the heating element assembly to the bowl. This will remove the heating element and the thermostat.
  11. Aroma ARC-914SBD Power Cord Replacement, Control Module: paso 11, imagen 1 de 1
    • Unplug the interface from the control module
  12. Aroma ARC-914SBD Power Cord Replacement: paso 12, imagen 1 de 1
    • Unplug the power from the control module
  13. Aroma ARC-914SBD Power Cord Replacement, Power Cord: paso 13, imagen 1 de 3 Aroma ARC-914SBD Power Cord Replacement, Power Cord: paso 13, imagen 2 de 3 Aroma ARC-914SBD Power Cord Replacement, Power Cord: paso 13, imagen 3 de 3
    • Locate the hidden screw behind the label and then remove it using a Phillips head screwdriver, size PH2.
  14. Aroma ARC-914SBD Power Cord Replacement: paso 14, imagen 1 de 2 Aroma ARC-914SBD Power Cord Replacement: paso 14, imagen 2 de 2
    • Pry the black base from the stainless steel housing while pushing down on black base from inside the device. This step is much easier with two people. One person can pry while the other pushes.
  15. Aroma ARC-914SBD Power Cord Replacement: paso 15, imagen 1 de 1
    • Using pliers, rotate the power cord clockwise to align it with the hole and simply pull it through.
Conclusión
Brandon Nieves
Miembro Desde 09/04/15
956 Reputación
8 Guías creadas
Equipo
USF Tampa, Team 2-3, Sullivan Fall 2015 Miembro de USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Miembros
8 Guías creadas
2 comentarios
I have ARC 5000SB - wanted to use this in India under 220V. Tried removing to see if I can attach voltage transformer in control circuit .. I am pretty sure no issue to heater. But couldn’t open fully … some wires are attached to lid and not possible to open upper plastic rim to access bottom circuit… any suggestions
K S Ravi Kumar - Contestar
Yeah, we had a lot of trouble opening it, we had to pry off the plastic from the metal to get access to those wires. It will break a few plastic tabs that hold it firmly in the metal ring. These really as we found serve no function other than preventing you from opening the cooker. It just is a hassle to get open so that you can work on these wires.
Tyler Gehring -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 14
Ultimos 30 días: 38
Todo El Tiempo: 1,471
