Saltar al contenido principal
ArmorAll AA255 Motor Replacement
Qué necesitas
  1. ArmorAll AA255 Motor Replacement, Lower Motor Housing: paso 1, imagen 1 de 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Motor Replacement: paso 2, imagen 1 de 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Motor Replacement: paso 3, imagen 1 de 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Motor Replacement: paso 4, imagen 1 de 2 ArmorAll AA255 Motor Replacement: paso 4, imagen 2 de 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Motor Replacement, Motor: paso 5, imagen 1 de 3 ArmorAll AA255 Motor Replacement, Motor: paso 5, imagen 2 de 3 ArmorAll AA255 Motor Replacement, Motor: paso 5, imagen 3 de 3
    • Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
    • Pull the ball cage to remove it from the main housing.
  6. ArmorAll AA255 Motor Replacement: paso 6, imagen 1 de 3 ArmorAll AA255 Motor Replacement: paso 6, imagen 2 de 3 ArmorAll AA255 Motor Replacement: paso 6, imagen 3 de 3
    • Remove one 13mm nut from the main housing.
    • The metal ring under the nut has sharp edges. You may need to use a tool such as pliers to prevent injury.
    • Remove metal ring from the main housing.
    • Use a PH2 screwdriver to remove the four 12mm screws from the main housing.
  7. ArmorAll AA255 Motor Replacement: paso 7, imagen 1 de 3 ArmorAll AA255 Motor Replacement: paso 7, imagen 2 de 3 ArmorAll AA255 Motor Replacement: paso 7, imagen 3 de 3
    • Turn the whole body over to separate motor cover.
    • Use a PH2 screwdriver to remove the five 15mm screw.
    • Remove the white power wire from the motor cover.
    • Pull the motor cover from the main housing.
  8. ArmorAll AA255 Motor Replacement: paso 8, imagen 1 de 2 ArmorAll AA255 Motor Replacement: paso 8, imagen 2 de 2
    • Use a plastic opening tool to remove two cables from the motor. One white cable is from the power cord, and one black cable is from the switch.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • You may need to mark the color of the wire on each terminal for reassembly.
  9. ArmorAll AA255 Motor Replacement: paso 9, imagen 1 de 2 ArmorAll AA255 Motor Replacement: paso 9, imagen 2 de 2
    • The motor is ready for replacement. Pull the motor to separate.
Conclusión
6 personas más completaron esta guía.
YeaJun Yoo
Miembro Desde 02/11/16
302 Reputación
1 Guía escrita
Equipo
IUPUI, Team 2-1, Baechle Spring 2016 Miembro de IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 Miembros
4 Guías creadas
4 comentarios
What is the motor product no? It will help if there is a link to buy the motor
Austin K - Contestar
Medida de los carboncitos que lleva el motor?
SERVANDO ARTEA FAVELA - Contestar
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
erikazavala2882 - Contestar
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
A Anderson - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 14
Ultimos 30 días: 63
Todo El Tiempo: 3,966
