Saltar al contenido principal
Archos Jukebox Recorder 20 Motherboard Replacement
Qué necesitas
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: paso 2, imagen 1 de 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: paso 3, imagen 1 de 1
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: paso 4, imagen 1 de 1
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: paso 5, imagen 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: paso 5, imagen 2 de 2
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: paso 6, imagen 1 de 1
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: paso 7, imagen 1 de 1
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: paso 8, imagen 1 de 1
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: paso 9, imagen 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: paso 9, imagen 2 de 2
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: paso 10, imagen 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: paso 10, imagen 2 de 2
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Conclusión
Shaun Rifield
Miembro Desde 03/21/18
121 Reputación
1 Guía escrita
Equipo
IUPUI, Team S2-G3, Freund Spring 2018 Miembro de IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 9
Ultimos 30 días: 14
Todo El Tiempo: 400
