Saltar al contenido principal
Archos Jukebox Recorder 20 Hard Drive Replacement
Qué necesitas
  1. Archos Jukebox Recorder 20 Hard Drive  Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 2, imagen 1 de 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: paso 3, imagen 1 de 2 Archos Jukebox Recorder 20 Hard Drive  Replacement, Hard Drive: paso 3, imagen 2 de 2
    • Use the T10 Torx Screwdriver to remove the 2 torx screws on each side of the device.
    • Two on each side for a total of four.
  4. Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 4, imagen 1 de 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 4, imagen 2 de 2
    • Remove the 2 screws on the top and the 2 screws on the bottom of the device using a Phillips #0 screwdriver.
  5. Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 5, imagen 1 de 1
    • Remove the outer metal casing of the device by popping it off with a plastic opening tool.
  6. Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 6, imagen 1 de 1
    • Remove the rubber bumpers on all four corners of the device.
  7. Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 7, imagen 1 de 2 Archos Jukebox Recorder 20 Hard Drive  Replacement: paso 7, imagen 2 de 2
    • Lift the hard drive out of its casing with the help of a plastic opening tool and slide it out. This will disconnect the pins connecting the drive to the rest of the device.
Conclusión
2 personas más completaron esta guía.
Aidan Patterson
Miembro Desde 01/08/18
354 Reputación
2 Guías creadas
Equipo
IUPUI, Team S1-G4, Freund Spring 2018 Miembro de IUPUI, Team S1-G4, Freund Spring 2018
IUPUI-FREUND-S18S1G4
3 Miembros
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 1,320
