Saltar al contenido principal
Aquarium Top Filter Box Replacement
Qué necesitas
  1. Aquarium Top Filter Box Replacement, Aquarium Filter Box: paso 1, imagen 1 de 2 Aquarium Top Filter Box Replacement, Aquarium Filter Box: paso 1, imagen 2 de 2
    • Using a black sharpie marker, mark the box for accurate holes.
    • Make sure the hole is a little bit smaller than the soft PVC pipe.
  2. Aquarium Top Filter Box Replacement: paso 2, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 2, imagen 2 de 2
    • Use the utility knife to cut a hole in the marked position to attach the pipe.
    • Be very careful as the box is difficult to cut.
  3. Aquarium Top Filter Box Replacement: paso 3, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 3, imagen 2 de 2
    • Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
  4. Aquarium Top Filter Box Replacement: paso 4, imagen 1 de 1
    • Attach the soft PVC pipe with the aquarium powerhead.
    • Make sure it is properly connected.
  5. Aquarium Top Filter Box Replacement: paso 5, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 5, imagen 2 de 2
    • Insert the soft PVC pipe in the plastic box.
  6. Aquarium Top Filter Box Replacement: paso 6, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 6, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 6, imagen 3 de 3
    • With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
  7. Aquarium Top Filter Box Replacement: paso 7, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 7, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 7, imagen 3 de 3
    • Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
    • Make sure to let the silicone glue dry for 30 minutes.
  8. Aquarium Top Filter Box Replacement: paso 8, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 8, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 8, imagen 3 de 3
    • Add your desired filter media best suited for your aquarium.
Conclusión
Una persona más ha completado esta guía.
Seaaf
Miembro Desde 05/12/21
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 46
Todo El Tiempo: 547
