Saltar al contenido principal
Aquarium Top Filter Box Replacement
Qué necesitas
  1. Aquarium Top Filter Box Replacement, Aquarium Filter Box: paso 1, imagen 1 de 2 Aquarium Top Filter Box Replacement, Aquarium Filter Box: paso 1, imagen 2 de 2
    • Using a black sharpie marker, mark the box for accurate holes.
    • Make sure the hole is a little bit smaller than the soft PVC pipe.
  2. Aquarium Top Filter Box Replacement: paso 2, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 2, imagen 2 de 2
    • Use the utility knife to cut a hole in the marked position to attach the pipe.
    • Be very careful as the box is difficult to cut.
  3. Aquarium Top Filter Box Replacement: paso 3, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 3, imagen 2 de 2
    • Using the same utility knife, make a hole in the bottom of the plastic box for the water to come out.
  4. Aquarium Top Filter Box Replacement: paso 4, imagen 1 de 1
    • Attach the soft PVC pipe with the aquarium powerhead.
    • Make sure it is properly connected.
  5. Aquarium Top Filter Box Replacement: paso 5, imagen 1 de 2 Aquarium Top Filter Box Replacement: paso 5, imagen 2 de 2
    • Insert the soft PVC pipe in the plastic box.
  6. Aquarium Top Filter Box Replacement: paso 6, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 6, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 6, imagen 3 de 3
    • With a telfon tape properly wrap the soft PVC pipe for no leakage of water.
  7. Aquarium Top Filter Box Replacement: paso 7, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 7, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 7, imagen 3 de 3
    • Use aquarium-safe silicone glue to seal the soft PVC pipe with the plastic box.
    • Make sure to let the silicone glue dry for 30 minutes.
  8. Aquarium Top Filter Box Replacement: paso 8, imagen 1 de 3 Aquarium Top Filter Box Replacement: paso 8, imagen 2 de 3 Aquarium Top Filter Box Replacement: paso 8, imagen 3 de 3
    • Add your desired filter media best suited for your aquarium.
    • Finally, submerge the waterpump in water and adjust the waterflow.
    • Be careful were you place the inlet of the filter, so no organisms or substrate get sucked in and die inside or clog it. If needed you can put some filter floss or a sponge on the inlet to prevent the above.
Conclusión
Una persona más ha completado esta guía.
Seaaf
Miembro Desde 05/12/21
181 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 7
Todo El Tiempo: 1,019
