Introducción
Use this guide to replace an old or worn out battery in your bq Aquaris M5.
Qué necesitas
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
15 personas más completaron esta guía.
4 comentarios
Very nice guide. I had seen videos on YouTube, however not one of them made it clear that one of the screws is different and therefore should be kept apart. Whereas in this guide, that fact is extremely clear. So thank you. And keep up the good work.
Mit ein paar Bildern besser erklärt als manches Video was im WWW es versucht… danke.
Super Dankeschön. Habe es auf Anhieb hin bekommen .super erklärt
Prima Job! Mit dieser Anleitung habe ich alles in den Griff bekommen!Danke :-)
