Saltar al contenido principal
Apple iSight Webcam Privacy Lens Replacement
Qué necesitas
  1. Apple iSight Webcam Privacy Lens Replacement, External Body Frame: paso 1, imagen 1 de 1
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Privacy Lens Replacement: paso 2, imagen 1 de 1
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Privacy Lens Replacement: paso 3, imagen 1 de 2 Apple iSight Webcam Privacy Lens Replacement: paso 3, imagen 2 de 2
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Privacy Lens Replacement, Privacy Lens: paso 4, imagen 1 de 1
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Privacy Lens Replacement: paso 5, imagen 1 de 2 Apple iSight Webcam Privacy Lens Replacement: paso 5, imagen 2 de 2
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Privacy Lens Replacement: paso 6, imagen 1 de 1
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Privacy Lens Replacement: paso 7, imagen 1 de 1
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Privacy Lens Replacement: paso 8, imagen 1 de 1
    • Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
  9. Apple iSight Webcam Privacy Lens Replacement: paso 9, imagen 1 de 2 Apple iSight Webcam Privacy Lens Replacement: paso 9, imagen 2 de 2
    • ,Pull the loose circuit strip from its connection using tweezers.
    • Do this for the side connection as well. This enables the entire camera lens section to come off.
    • Pull the camera lens section off the main body.
  10. Apple iSight Webcam Privacy Lens Replacement: paso 10, imagen 1 de 2 Apple iSight Webcam Privacy Lens Replacement: paso 10, imagen 2 de 2
    • Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture.
    • Then pull off the circuitry top section.
  11. Apple iSight Webcam Privacy Lens Replacement: paso 11, imagen 1 de 2 Apple iSight Webcam Privacy Lens Replacement: paso 11, imagen 2 de 2
    • Pull off the top piece of the lens aperture.
    • Finally, remove the privacy lens using tweezers.
Conclusión
4 personas más completaron esta guía.
Cullen Shorey
Miembro Desde 03/21/18
271 Reputación
1 Guía escrita
Equipo
IUPUI, Team S5-G1, Baechle Spring 2018 Miembro de IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
3 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 1,171
