Introducción
This guide details how to replace the dock inserts of the Apple iPod Hi-Fi speaker system.
Qué necesitas
Take one spudger and fit it under the grille.
Use your first spudger to pry up and make room to insert a second one.
Sever the glue connections between the grille and the device by moving one spudger around, cutting through the glue.
Use the other spudger to raise the grille, allowing you to see where you're working.
Remove all eight 3.3mm JIS #1 screws holding the front panel in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
Remove the four 3.3mm JIS #1 screws holding the large speaker in place by placing the screwdriver in the head of the screw and rotating counterclockwise.
5 personas más completaron esta guía.
Un comentario
If I need broken part of Apple iPod Hi-Fi iPod Dock were to get and how to get it part
