Introducción
During this guide you will need some solder skills to repair the product. If you don't have any experiences in soldering, take a look at the How to Solder and Desolder Connections guide. Make sure you have all the tools that's needed to desolder en solder. Be aware of the fumes—do this in a well ventilated room!
Qué necesitas
Unscrew the four Phillips screws on the backside of the docking system.
Herramienta utilizada en este paso:Desoldering Pump$3.99
Trigger the desoldering pump before heating the solder.
Om het apparaat weer te monteren, volg je deze instructies in omgekeerde volgorde vanaf stap 7.
