Saltar al contenido principal
Apple XServe Raid Battery Replacement
Qué necesitas
  1. Apple XServe Raid Battery Replacement, Raid Battery: paso 1, imagen 1 de 2 Apple XServe Raid Battery Replacement, Raid Battery: paso 1, imagen 2 de 2
    • Remove the drive module(s) from the front of the Xserve.
    • Depending on configuration, there may be up to three modules.
  2. Apple XServe Raid Battery Replacement: paso 2, imagen 1 de 1
    • Remove the power supplies from the system by pulling on the built-in removal bar.
    • Depending on configuration, there may only be one power supply unit.
  3. Apple XServe Raid Battery Replacement: paso 3, imagen 1 de 1
    • Remove the top cover of the system by loosening the two thumb screws located on the back panel.
    • Discharge any static electricity by touching a grounded surface. Failure to do so may cause damage to the internal components.
  4. Apple XServe Raid Battery Replacement: paso 4, imagen 1 de 3 Apple XServe Raid Battery Replacement: paso 4, imagen 2 de 3 Apple XServe Raid Battery Replacement: paso 4, imagen 3 de 3
    • Remove the fan module by loosening the two Phillips #0 screws located on each side of the module.
  5. Apple XServe Raid Battery Replacement: paso 5, imagen 1 de 1
    • Disconnect the raid battery connector using a plastic spudger.
  6. Apple XServe Raid Battery Replacement: paso 6, imagen 1 de 2 Apple XServe Raid Battery Replacement: paso 6, imagen 2 de 2
    • Remove the SAS backplane power cable by pulling the cable out of the board.
    • Remove the data cable from the board using a spudger to lift the connector out of the socket.
    • Loosen the Phillips #0 screw holding the backplane in the system.
    • To remove the backplane from the chassis, slide the board down, tilt it to a 45 degree angle, and pull the board out.
  7. Apple XServe Raid Battery Replacement: paso 7, imagen 1 de 1
    • Loosen the single Phillips #0 screw on the power backplane.
    • Slide the backplane out of the connector on the main board, and lift it straight out.
  8. Apple XServe Raid Battery Replacement: paso 8, imagen 1 de 1
    • Lift the raid card battery out of the chassis.
Conclusión
2 personas más completaron esta guía.
Cody West
Miembro Desde 10/20/20
234 Reputación
1 Guía escrita
Equipo
Texas Tech, Team S14-G2, Cowan Fall 2020 Miembro de Texas Tech, Team S14-G2, Cowan Fall 2020
TTU-COWAN-F20S14G2
1 Miembro
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 7
Todo El Tiempo: 862
