Saltar al contenido principal
Apple Time Capsule Model A1254 - Replacing the power supply capacitors
Qué necesitas
  1. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Open the Time Capsule: paso 1, imagen 1 de 1
    • Using the fingers or a blunt, plastic tool, peel away the rubber base.
    • Be careful as in some older Time Capsules, it may be that the rubber base is torn. Please perform the step slowly and with care.
  2. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Accessing the Power Board: paso 2, imagen 1 de 1
    • Remove the 7 marked screws in order to remove the aluminum bottom and free the power supply board.
    • Once the bottom is removed, disconnect the fan cord from the motherboard.
  3. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Disconnect the power supply board: paso 3, imagen 1 de 1
    • The power supply board is not held in by any screws (removed in the previous step).
    • Disconnect the SATA power connector from the drive, the connector from the motherboard, and the power plug.
    • Gently pull out the power supply board.
  4. Apple Time Capsule Model A1254 - Replacing the power supply capacitors: paso 4, imagen 1 de 2 Apple Time Capsule Model A1254 - Replacing the power supply capacitors: paso 4, imagen 2 de 2
    • Gently peel off the aluminum tape on the label side, then pull it aside.
    • Insert translation here
  5. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Identify broken capacitor: paso 5, imagen 1 de 2 Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Identify broken capacitor: paso 5, imagen 2 de 2
    • Once the card is out and the capacitors are visible, you have to look for those which are bulging.
    • The second photo is not of good quality, but it is the one on the left which is bulging.
    • In any case, you must replace the capacitors by pair. Here, it is the two big ones which will be changed.
  6. Apple Time Capsule Model A1254 - Replacing the power supply capacitors: paso 6, imagen 1 de 1
    • The capacitors are unstuck, straightened and ready to be unsoldered.
  7. Apple Time Capsule Model A1254 - Replacing the power supply capacitors, Replacing Capacitors: paso 7, imagen 1 de 1
    • The two new capacitors are in place.
    • WARNING: if during reassembly, the capsule goes into a "high temperature" alarm on Airport, with the fan running and the orange light flashing, this is probably due to contact between the "-" leg of the lower capacitor and the wire below.
    • To avoid the above problem, you have to put the small silicone tube removed from the old capacitor back, and don't hesitate to put a bit of nail polish to hold it together.
Conclusión
To reassemble your device, follow the instructions in reverse order.
3 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
fr en
100%
Estos traductores nos están ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Madcat
Miembro Desde 10/06/19
725 Reputación
5 Guías creadas
Un comentario
Merci
Je vais tenter la réparation
Le temps d’acheter les condos
Beau Seck - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 20
Ultimos 30 días: 68
Todo El Tiempo: 1,850
