Saltar al contenido principal
Apple Thunderbolt Display EMI Filter Replacement
Qué necesitas
  1. Apple Thunderbolt Display EMI Filter Replacement, LCD: paso 1, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement, LCD: paso 1, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement, LCD: paso 1, imagen 3 de 3
    • Lay down the display with screen side up.
    • Since the display is able to be tilted up and down, we found it useful to prop up the screen up with a styrofoam block in between the screen and the base.
    • Place the two suction cups on both sides of the top of the screen and make sure to lock them in place.
    • The glass screen is connected to the rest of the display by small magnets. Lift slowly and the screen will come right off.
  2. Apple Thunderbolt Display EMI Filter Replacement: paso 2, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement: paso 2, imagen 2 de 2
    • Unscrew the 12 screws around the side edges and the top of the LCD with the TR 10 Screwdriver.
  3. Apple Thunderbolt Display EMI Filter Replacement: paso 3, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement: paso 3, imagen 2 de 2
    • Slowly lift the LCD out from its placement and tilt it upwards.
    • It can be very helpful to have an extra set of hands to hold the LCD up while you work with the cables underneath.
    • There are four wires that connect the LCD to the rest of the components. Make sure not to pull hard and break any of the wires.
  4. Apple Thunderbolt Display EMI Filter Replacement: paso 4, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 4, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 4, imagen 3 de 3
    • For the first of the four wires (furthest away from the wire that is held in by a screw), grab onto the connector and pull slowly.
  5. Apple Thunderbolt Display EMI Filter Replacement: paso 5, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 5, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 5, imagen 3 de 3
    • For the next connector, which is right next to the previous wire, there is a piece of tape attached to a metal bar.
    • Flip the metal bar over using the tape as a handle.
    • Next, grab onto the connector and slowly pull it from the socket in the logic board.
  6. Apple Thunderbolt Display EMI Filter Replacement: paso 6, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 6, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 6, imagen 3 de 3
    • For the connector on the other side of the logic board, grab the connector from underneath and carefully pull it from the board.
  7. Apple Thunderbolt Display EMI Filter Replacement: paso 7, imagen 1 de 1
    • For the last wire connecting to the LCD, use your T 10 Screwdriver to remove the screw.
  8. Apple Thunderbolt Display EMI Filter Replacement: paso 8, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement: paso 8, imagen 2 de 2
    • The LCD has now been fully disconnected from the casing and can be repaired/replaced!
    • its best to set the LCD on a bed or on a thick towel to avoid damage to the LCD
  9. Apple Thunderbolt Display EMI Filter Replacement, EMI Filter: paso 9, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement, EMI Filter: paso 9, imagen 2 de 2
    • You should now see the EMI filter right in the middle of the device (although held in by a few other components).
    • Follow the wires coming out of the bottom of the Power adapter off to the left.
    • Take the tweezers and remove the piece of tape holding the wires to the casing.
    • There is only one connector that needs to be taken out (even though there are two right next to each other!).
    • Grab the connector from the bottom and pull it carefully from its corresponding socket.
  10. Apple Thunderbolt Display EMI Filter Replacement: paso 10, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement: paso 10, imagen 2 de 2
    • Next, remove the piece of electrical tape that is holding wires into the casing connecting to the power adapter.
  11. Apple Thunderbolt Display EMI Filter Replacement: paso 11, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 11, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 11, imagen 3 de 3
    • The surrounding speaker component (the black box) around the power inlet needs to be removed.
    • Use the TR 10 screwdriver to remove the four screws.
    • Disconnect the speaker from behind the logic board by carefully pulling at the plastic end of the cable.
    • Remove the speaker.
  12. Apple Thunderbolt Display EMI Filter Replacement: paso 12, imagen 1 de 2 Apple Thunderbolt Display EMI Filter Replacement: paso 12, imagen 2 de 2
    • Now that the middle speaker is out of the way, the EMI filter is easily accessible.
    • Using tweezers, remove the silver tape that is at the top of the filter.
  13. Apple Thunderbolt Display EMI Filter Replacement: paso 13, imagen 1 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 13, imagen 2 de 3 Apple Thunderbolt Display EMI Filter Replacement: paso 13, imagen 3 de 3
    • The EMI filter is connected by three screws. Use the T10 screwdriver to remove them.
    • The screw that holds in both the filter and a wire that is connected to it is a different size and should be kept identifiable from the other two screws.
    • The green and yellow wire that was held in by the different screw is tucked behind another component. To get it out, squeeze it behind the black wire and the filter will be able to be removed from the casing.
Conclusión
11 personas más completaron esta guía.
Calvin Laverty
Miembro Desde 04/14/15
2,240 Reputación
4 Guías creadas
Equipo
Cal Poly, Team 5-11, Maness Spring 2015 Miembro de Cal Poly, Team 5-11, Maness Spring 2015
CPSU-MANESS-S15S5G11
4 Miembros
19 Guías creadas
7 comentarios
Power adapter? That's the AC EMI filter, right? My power supply looks like this:
http://www.dvwarehouse.com/661-6048-661-...
The EMI filter will never fail... well, maybe a direct lightning strike.
roger - Contestar
That is definitely just a filter. The power supply is the big PCB connected to it. One could say this is an EMI filter along with an IEC input connector...this guide is only useful if you want to replace the connector rather than the actual power supply.
Garrett Mace -
Not sure if the EMI filter will NEVER fail as someone said above. Mine was buzzing and I replaced it and this fixed one of my displays that was buzzing. There are also other causes, including capacitors on the Power Supply board, worn out fan etc.
Charlie Nancarrow -
So are we saying that this is wrong? anyone? I really need to replace my power supply.
Stewart Sensor - Contestar
I replace the all in one lightning and charge cable but it has ended up that the lightning cable only works. I thought I connected everything up fine but which connector would stop the charge cable working?
pdspanagel - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 16
Ultimos 30 días: 72
Todo El Tiempo: 17,155
