Saltar al contenido principal
Apple TV 4K Remote Logic Board Replacement
Qué necesitas
  1. Apple TV 4K Remote Logic Board Replacement, Remote Logic Board: paso 1, imagen 1 de 1
    • Heat iOpener according to manufacturer's instructions.
    • Place over the face of the remote to soften the adhesive under the glass.
  2. Apple TV 4K Remote Logic Board Replacement: paso 2, imagen 1 de 2 Apple TV 4K Remote Logic Board Replacement: paso 2, imagen 2 de 2
    • Using a spudger, gently lift the face of the remote. Starting from the bottom and working your way to the top.
  3. Apple TV 4K Remote Logic Board Replacement: paso 3, imagen 1 de 1
    • Push front face forward to disengage plastic clips at the top of the remote.
  4. Apple TV 4K Remote Logic Board Replacement: paso 4, imagen 1 de 2 Apple TV 4K Remote Logic Board Replacement: paso 4, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Unlatch the connector that binds the touch screen and logic board.
    • Afterwards, use tweezers to detach the connector that binds the touch screen to the logic board.
  5. Apple TV 4K Remote Logic Board Replacement: paso 5, imagen 1 de 1
    • Lift the face from the body of the remote.
  6. Apple TV 4K Remote Logic Board Replacement: paso 6, imagen 1 de 2 Apple TV 4K Remote Logic Board Replacement: paso 6, imagen 2 de 2
    • Lift the latch holding back the connector to the battery.
    • Use tweezers to disconnect the battery connector.
  7. Apple TV 4K Remote Logic Board Replacement: paso 7, imagen 1 de 1
    • Remove the following screws using a T3 Torx screwdriver:
    • Eight 2mm screws
  8. Apple TV 4K Remote Logic Board Replacement: paso 8, imagen 1 de 1
    • Using a plastic spudger, gently remove the logic board from the case of the remote.
Conclusión
2 personas más completaron esta guía.
Keenan Barber
Miembro Desde 10/04/18
1,159 Reputación
3 Guías creadas
Equipo
UW Stout, Team S6-G3, Ogden Fall 2018 Miembro de UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Miembros
15 Guías creadas
Un comentario
Have you ever successfully reconnected the ribbon cable after disassembly? It seems nearly impossible to do by hand…
B R - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 7
Ultimos 7 días: 22
Ultimos 30 días: 109
Todo El Tiempo: 4,601
