Introducción
In this guide we will disassemble and remove the power supply from an Apple TV 4K
Qué necesitas
Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
Use a T7 Torx to remove the screws:
Five 5mm screws
Carefully flip the device upside down to remove the logic board/power supply mount.
9 personas más completaron esta guía.
8 comentarios
Please, explain the 12V power supply topic: does that means it can be installed in a car or a boat out of the box?
