Saltar al contenido principal
Apple TV 4K Power Connector Replacement
Qué necesitas
  1. Apple TV 4K Power Connector Replacement, Logic Board: paso 1, imagen 1 de 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Power Connector Replacement: paso 2, imagen 1 de 2 Apple TV 4K Power Connector Replacement: paso 2, imagen 2 de 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Power Connector Replacement: paso 3, imagen 1 de 2 Apple TV 4K Power Connector Replacement: paso 3, imagen 2 de 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Power Connector Replacement: paso 4, imagen 1 de 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Power Connector Replacement: paso 5, imagen 1 de 3 Apple TV 4K Power Connector Replacement: paso 5, imagen 2 de 3 Apple TV 4K Power Connector Replacement: paso 5, imagen 3 de 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
  6. Apple TV 4K Power Connector Replacement, Power Connector: paso 6, imagen 1 de 3 Apple TV 4K Power Connector Replacement, Power Connector: paso 6, imagen 2 de 3 Apple TV 4K Power Connector Replacement, Power Connector: paso 6, imagen 3 de 3
    • Use a T7 Torx to remove the screws:
    • Five 5mm screws
    • Carefully flip the device upside down to remove the logic board/power supply mount.
  7. Apple TV 4K Power Connector Replacement: paso 7, imagen 1 de 3 Apple TV 4K Power Connector Replacement: paso 7, imagen 2 de 3 Apple TV 4K Power Connector Replacement: paso 7, imagen 3 de 3
    • Disconnect the latch connecting the power connector to the power supply.
    • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
Conclusión
Brian Gehring
Miembro Desde 10/04/18
451 Reputación
2 Guías creadas
Equipo
UW Stout, Team S6-G3, Ogden Fall 2018 Miembro de UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 15
Ultimos 30 días: 45
Todo El Tiempo: 2,851
