Saltar al contenido principal
Apple TV 3rd Generation Logic Board Replacement
Qué necesitas
  1. Apple TV 3rd Generation Logic Board Replacement, Snap-on Base: paso 1, imagen 1 de 1
    • As the device base is firmly clipped, insert two metal spudgers to gently release the first clips.
  2. Apple TV 3rd Generation Logic Board Replacement: paso 2, imagen 1 de 1
    • Continue releasing the last plastic clips with your hands taking care not to break any of the plastic elements attached to the base.
  3. Apple TV 3rd Generation Logic Board Replacement, Logic Board: paso 3, imagen 1 de 1
    • Use a philips screwdriver to remove the 5 screws securing the metal heat sink. On Rev A (A1469) you need a T7 srewdriver
  4. Apple TV 3rd Generation Logic Board Replacement: paso 4, imagen 1 de 2 Apple TV 3rd Generation Logic Board Replacement: paso 4, imagen 2 de 2
    • Disconnect the power supply connector from the logic board with a spudger.
Conclusión
10 personas más completaron esta guía.
Vincent Monteil
Miembro Desde 07/06/13
6,975 Reputación
19 Guías creadas
4 comentarios
Where can I find a 3rd Generation Apple TV Logic Board?
Ricky Vaughn - Contestar
Good question! Did you manage to find a replacement?
Nathan Bugeja -
Hi my wifi and athernet is not working in apple tv on screen it showing your apple tv is connected to local network its not connect to internet now how should i repair this
Mohamed Iqbal Sayyed - Contestar
Mine too, where could I find a logic board replacement???
Juan Ignacio Gutierrez I. -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 25
Todo El Tiempo: 9,680
