Introducción
Removing the logic board is a very simple procedure. Hopefully you never have to do this to your Apple TV. Just a note... There is nothing wrong with my Apple TV. I made this guide for those that may need to use it one day. My Apple TV is still running well
Herramientas
Partes
No se especificaron partes.
Use a spudger to pry the bottom cover off the Apple TV.
It may be necessary to use two spudgers (one to hold it open while you pry with the other one)
Use a flathead screwdriver or spudger to tilit the logic board to an angle so you can grab it with your hands
Holding the logic board by it edges, lift it up slightly.
And remove
Thats all. The logic board has been removed. Just follow the steps (Step 1-5 in reverse to install the board)
7 personas más completaron esta guía.
