Introducción
Time and general wear and tear of the Apple TV can cause damage to the bottom cover. This guide will show how to replace the bottom cover on the Apple TV 2nd generation device.
Qué necesitas
Herramienta utilizada en este paso:Metal Spudger$2.99
As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
Casi Terminas!
Conclusión
