Saltar al contenido principal
Apple Studio Display M7649 Rear Panel Replacement
Qué necesitas
  1. Apple Studio Display M7649 Rear Panel Replacement, Stand: paso 1, imagen 1 de 2 Apple Studio Display M7649 Rear Panel Replacement, Stand: paso 1, imagen 2 de 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Apple Studio Display M7649 Rear Panel Replacement, Panels: paso 2, imagen 1 de 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Apple Studio Display M7649 Rear Panel Replacement: paso 3, imagen 1 de 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Apple Studio Display M7649 Rear Panel Replacement: paso 4, imagen 1 de 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Linea de Meta
2 personas más completaron esta guía.
Alan Truong
Miembro Desde 01/19/10
566 Reputación
3 Guías creadas
Equipo
Cal Poly, Team 3-20, Maness Winter 2010 Miembro de Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Miembros
15 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 11
Todo El Tiempo: 3,721
