Saltar al contenido principal
Apple Studio Display M2454 CCFL Inverter Replacement
Qué necesitas
  1. Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: paso 1, imagen 1 de 2 Apple Studio Display M2454 CCFL Inverter Replacement, CCFL Inverter: paso 1, imagen 2 de 2
    • First remove the three 2mm hex screws from the top of the monitors stand.
    • Then, remove the four 2mm hex screws on the corners of the back panel.
    • Finally, the back panels can be removed by pulling the main cable through the opening and sliding the panels away.
  2. Apple Studio Display M2454 CCFL Inverter Replacement: paso 2, imagen 1 de 1
    • Remove the metal backing.
    • Remove the single screw at the top and the two screws at the bottom of the monitor with #2 philips head screwdriver.
    • With the screws removed, push metal backing toward back of monitor to release its clips and pull away.
  3. Apple Studio Display M2454 CCFL Inverter Replacement: paso 3, imagen 1 de 1
    • Now, with the circuitry exposed, locate the CCFL inverter board.
    • Look for the smaller of the two circuit boards with two wires and a ribbon cable running out of it.
  4. Apple Studio Display M2454 CCFL Inverter Replacement: paso 4, imagen 1 de 1
    • Now the connections from the board need to be removed.
    • Remove the two cables on the left side of the board, using a pin to insert into the two small holes and then pull out.
    • This step may be easier with two people.
    • Do not insert pin in hole with force or you risk damaging the connector.
  5. Apple Studio Display M2454 CCFL Inverter Replacement: paso 5, imagen 1 de 1
    • Remove the ribbon cable on the right side of board by pulling it away from the LCD main board with hand.
  6. Apple Studio Display M2454 CCFL Inverter Replacement: paso 6, imagen 1 de 1
    • Remove the top philips head screws holding the board to the monitor with #2 philips head screwdriver.
  7. Apple Studio Display M2454 CCFL Inverter Replacement: paso 7, imagen 1 de 1
    • Remove the bottom philips head screw and pull the CCFL Inverter board away from monitor.
    • To replace this part with a new one, simply follow these directions in reverse using the new board.
Linea de Meta
Una persona más ha completado esta guía.
Dylan Perry
Miembro Desde 01/20/10
177 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 13-27, Maness Winter 2010 Miembro de Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Miembros
9 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 37
Todo El Tiempo: 6,525
