Saltar al contenido principal
Apple Powerbook 5300 Battery Replacement
  1. Apple Powerbook 5300 Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
Conclusión
Una persona más ha completado esta guía.
Equipo
Cal Poly, Team 25-30, Garner Spring 2011 Miembro de Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 11
Todo El Tiempo: 3,032
