Saltar al contenido principal
Apple Powerbook 520/540 General Disassembly
Qué necesitas
  1. Apple Powerbook 520/540 General Disassembly, Case: paso 1, imagen 1 de 2 Apple Powerbook 520/540 General Disassembly, Case: paso 1, imagen 2 de 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: paso 2, imagen 1 de 1
    • With monitor hinge at the bottom, remove the two top center screws.
  3. Apple Powerbook 520/540 General Disassembly: paso 3, imagen 1 de 1
    • Remove top left and top right screws.
  4. Apple Powerbook 520/540 General Disassembly: paso 4, imagen 1 de 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: paso 5, imagen 1 de 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
  6. Apple Powerbook 520/540 General Disassembly: paso 6, imagen 1 de 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: paso 7, imagen 1 de 3 Apple Powerbook 520/540 General Disassembly: paso 7, imagen 2 de 3 Apple Powerbook 520/540 General Disassembly: paso 7, imagen 3 de 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Conclusión
9 personas más completaron esta guía.
Mark McNeff
Miembro Desde 04/20/11
497 Reputación
2 Guías creadas
2 comentarios
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Contestar
Thanks been trying to fix this for a long time
Luke - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 41
Todo El Tiempo: 6,673
