Introducción
In order to obtain access to the internal components you must first follow this step by step general disassembly guide. This will be a first stop in installing a new component that is enclosed by the outer shell.
  1. Turn computer over.
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. With monitor hinge at the bottom, remove the two top center screws.
    • With monitor hinge at the bottom, remove the two top center screws.
    • Remove top left and top right screws.
    • Remove middle left and middle right screws.
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    • Lift keyboard from bottom and take out of shell.
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
Conclusión
7 personas más completaron esta guía.
Mark McNeff
Miembro Desde 20/04/11
469 Reputación
2 Guías creadas
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Contestar
Thanks been trying to fix this for a long time
Luke Legg - Contestar
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 19
Todo El Tiempo: 4,335
