Saltar al contenido principal
Introducción
This repair will need:
A T8 Torx Screwdriver.
Partes
No se especificaron partes.
  1. With the Generally Disassembly completed, you may proceed to floppy drive installation.
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Remove the plastic panel at the bottom of the display.
    • Remove the plastic panel at the bottom of the display.
  3. Reverse the computer to access the peripheral panel in the back.
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Reverse the computer to have the monitor and mousepad facing you.
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Remove the three T8 Torx screws securing the floppy drive to the frame.
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Lift the defective floppy drive from the body of the computer.
    • Lift the defective floppy drive from the body of the computer.
  8. Replace the defective drive with a new drive.
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
Conclusión
2 personas más completaron esta guía.
Kevin Peters
Miembro Desde 19/04/11
120 Reputación
1 Guía escrita
Equipo
Cal Poly, Team 20-66, Walters Spring 2011 Miembro de Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 Miembros
3 Guías creadas
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 2,340
