Saltar al contenido principal
Apple Powerbook 520 Battery Replacement
  1. Apple Powerbook 520 Battery Replacement, Remove Old Battery: paso 1, imagen 1 de 1
    • If battery is determined to be dysfunctional, a replacement is necessary.
    • First, remove battery from the battery slot located at the bottom right or left side of the base of the computer.
  2. Apple Powerbook 520 Battery Replacement, Swap Batteries: paso 2, imagen 1 de 1
    • Obtain a new or refurbished Powerbook Intelligent Battery with Model Number: M1906.
  3. Apple Powerbook 520 Battery Replacement, Insert New Battery: paso 3, imagen 1 de 1
    • Insert new battery into battery slot. Note: You should hear a click to know the battery is inserted properly.
Conclusión
6 personas más completaron esta guía.
Mark McNeff
Miembro Desde 04/20/11
497 Reputación
2 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 17
Todo El Tiempo: 3,503
