Saltar al contenido principal
Apple PowerBook G3 400 Keyboard Replacement
  1. Apple PowerBook G3 400 Keyboard Replacement, Keyboard: paso 1, imagen 1 de 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Keyboard Replacement: paso 2, imagen 1 de 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Keyboard Replacement: paso 3, imagen 1 de 1
    • Your computer should look approximately like this.
Conclusión
Byron Hoefer
Miembro Desde 04/18/11
70 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 4-2, Regan Spring 2011 Miembro de Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Miembros
6 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 7
Todo El Tiempo: 1,759
