Saltar al contenido principal
Apple Magic Keyboard 2 A2450 Keyboard Replacement
Qué necesitas
  1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: paso 1, imagen 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: paso 1, imagen 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: paso 1, imagen 3 de 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: paso 2, imagen 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: paso 2, imagen 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: paso 2, imagen 3 de 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 3, imagen 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 3, imagen 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 3, imagen 3 de 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 4, imagen 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 4, imagen 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 4, imagen 3 de 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
  5. Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 5, imagen 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 5, imagen 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 5, imagen 3 de 3
    • Use a T3 Torx screwdriver to remove the single 3 mm screw that secures the assembly to the frame.
    • Use tweezers to unplug the power switch from the case. Pull horizontally on the entire assembly to remove the switch from the keyboard.
  6. Apple Magic Keyboard 2 A2450 Keyboard Replacement: paso 6, imagen 1 de 1
    • Replace the keyboard.
Conclusión
Alex
Miembro Desde 04/02/24
217 Reputación
2 Guías creadas
Equipo
IUPUI, Team 3-2, Harley Spring 2024 Miembro de IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 Miembros
3 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 63
Todo El Tiempo: 90
