Saltar al contenido principal
Introducción
Use this guide to help you optimize audio function from your Apple EarPods.
  1. X-ACTO Knife Tweezer
    • X-ACTO Knife
    • Tweezer
    • Triangle Paddle
    • Alcohol
    • Cotton Swabs
  2. Using a triangle paddle, apply sufficient pressure to get in-between the opening section Using a triangle paddle, apply sufficient pressure to get in-between the opening section
    • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
  3. Soak one side of a cotton swab with alcohol
    • Soak one side of a cotton swab with alcohol
    • Clean inner and outer pod using swab soaked in alcohol
  4. Kits de Reparación de Batería de iPhone
    Sólo $29.99
    Buy Now
    Sólo $29.99
    Buy Now
  5. Carefully clean the speaker cone using cotton swab
    • Carefully clean the speaker cone using cotton swab
    • Once clean, reattach the earbud
  6. Carefully remove grill out of both earbuds using tweezers Take precautions not to bend grill excessively
    • Carefully remove grill out of both earbuds using tweezers
    • Take precautions not to bend grill excessively
  7. Clean grill with cotton swab soaked in alcohol
    • Clean grill with cotton swab soaked in alcohol
    • Remove any build up of wax or sweat
  8. Once the grill is clean, place the grill back inside of the apple earbuds Once the grill is clean, place the grill back inside of the apple earbuds
    • Once the grill is clean, place the grill back inside of the apple earbuds
Conclusión
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
Eduardo Gonzalez
Miembro Desde 31/10/18
145 Reputación
1 Guía escrita
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 58
Últimos 30 Días: 243
Todo El Tiempo: 1,629
